Ir para o conteúdo principal
ASUS X552LAV-BBI5N08 Hard Drive Replacement
O que você precisa
  1. ASUS X552LAV-BBI5N08 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Battery is not showed in pictures.
    • Flip the laptop face down.
  2. ASUS X552LAV-BBI5N08 Hard Drive Replacement: passo 2, imagem 1 %32 ASUS X552LAV-BBI5N08 Hard Drive Replacement: passo 2, imagem 2 %32 ASUS X552LAV-BBI5N08 Hard Drive Replacement: passo 2, imagem 3 %32
    • Slide the right button to the left.
    • Hold the left button to the right.
    • While you hold the left button in position, slide the battery out by pushing it away from you.
  3. ASUS X552LAV-BBI5N08 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32
    • Start by flipping the laptop face down.
    • Locate the bottom panel. It is at the opposite end of the battery.
    • Remove the two 12mm screws at the bottom panel with a Tri-wing Y1 screwdriver.
  4. ASUS X552LAV-BBI5N08 Hard Drive Replacement: passo 4, imagem 1 %32 ASUS X552LAV-BBI5N08 Hard Drive Replacement: passo 4, imagem 2 %32 ASUS X552LAV-BBI5N08 Hard Drive Replacement: passo 4, imagem 3 %32
    • Remove bottom panel by lifting it up.
    • Locate the hard drive.
    • It is located in the bottom left corner.
  5. ASUS X552LAV-BBI5N08 Hard Drive Replacement: passo 5, imagem 1 %32 ASUS X552LAV-BBI5N08 Hard Drive Replacement: passo 5, imagem 2 %32 ASUS X552LAV-BBI5N08 Hard Drive Replacement: passo 5, imagem 3 %32
    • Remove the four 5.5mm screws located on the hard drive case using a Tri-wing Y1 screwdriver.
    • Slide the hard drive out to the left.
  6. ASUS X552LAV-BBI5N08 Hard Drive Replacement: passo 6, imagem 1 %32 ASUS X552LAV-BBI5N08 Hard Drive Replacement: passo 6, imagem 2 %32
    • Lift the hard drive out.
    • Once the hard drive is removed, place the hard drive at a different area.
  7. ASUS X552LAV-BBI5N08 Hard Drive Replacement: passo 7, imagem 1 %32 ASUS X552LAV-BBI5N08 Hard Drive Replacement: passo 7, imagem 2 %32 ASUS X552LAV-BBI5N08 Hard Drive Replacement: passo 7, imagem 3 %32
    • Place the hard drive on its side.
    • Remove the four 5mm screws from the sides of the case by using a Tri-wing Y1 screwdriver.
    • Lift the hard drive out of the case.
Conclusão
Jason Vo
Membro desde: 02/15/18
857 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S17-G1, Boczar Spring 2018 Membro de USF Tampa, Team S17-G1, Boczar Spring 2018
USFT-BOCZAR-S18S17G1
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 311
