Ir para o conteúdo principal
ASUS X552LAV-BBI5N08 Fan Replacement
O que você precisa
  1. ASUS X552LAV-BBI5N08 Fan Replacement, Battery: passo 1, imagem 1 %32
    • Battery is not showed in pictures.
    • Flip the laptop face down.
  2. ASUS X552LAV-BBI5N08 Fan Replacement: passo 2, imagem 1 %32 ASUS X552LAV-BBI5N08 Fan Replacement: passo 2, imagem 2 %32 ASUS X552LAV-BBI5N08 Fan Replacement: passo 2, imagem 3 %32
    • Slide the right button to the left.
    • Hold the left button to the right.
    • While you hold the left button in position, slide the battery out by pushing it away from you.
  3. ASUS X552LAV-BBI5N08 Fan Replacement, Fan: passo 3, imagem 1 %32
    • Locate the bottom panel. It is at the opposite end of the battery.
    • Remove the two 12mm screws at the bottom panel with a Tri-wing Y1 screwdriver.
  4. ASUS X552LAV-BBI5N08 Fan Replacement: passo 4, imagem 1 %32 ASUS X552LAV-BBI5N08 Fan Replacement: passo 4, imagem 2 %32 ASUS X552LAV-BBI5N08 Fan Replacement: passo 4, imagem 3 %32
    • Remove bottom panel by lifting it up.
  5. ASUS X552LAV-BBI5N08 Fan Replacement: passo 5, imagem 1 %32 ASUS X552LAV-BBI5N08 Fan Replacement: passo 5, imagem 2 %32 ASUS X552LAV-BBI5N08 Fan Replacement: passo 5, imagem 3 %32
    • Remove the four 5.5mm screws located on the hard drive case using a Tri-wing Y1 screwdriver.
    • Slide the hard drive out to the left.
  6. ASUS X552LAV-BBI5N08 Fan Replacement: passo 6, imagem 1 %32 ASUS X552LAV-BBI5N08 Fan Replacement: passo 6, imagem 2 %32 ASUS X552LAV-BBI5N08 Fan Replacement: passo 6, imagem 3 %32
    • Use opening tool to split keyboard from base of the laptop.
    • Make sure to start from one end and go around the edges.
    • Use Tri-wing Y1 screwdriver to remove two 12mm screws from battery area.
  7. ASUS X552LAV-BBI5N08 Fan Replacement: passo 7, imagem 1 %32 ASUS X552LAV-BBI5N08 Fan Replacement: passo 7, imagem 2 %32 ASUS X552LAV-BBI5N08 Fan Replacement: passo 7, imagem 3 %32
    • Flip laptop to sit on its bottom.
    • Lift keyboard up by the front edge
  8. ASUS X552LAV-BBI5N08 Fan Replacement: passo 8, imagem 1 %32 ASUS X552LAV-BBI5N08 Fan Replacement: passo 8, imagem 2 %32 ASUS X552LAV-BBI5N08 Fan Replacement: passo 8, imagem 3 %32
    • Flip up the small locking flap for the two ZIF connectors.
    • Unplug connectors that are keeping keyboard connected
  9. ASUS X552LAV-BBI5N08 Fan Replacement: passo 9, imagem 1 %32 ASUS X552LAV-BBI5N08 Fan Replacement: passo 9, imagem 2 %32 ASUS X552LAV-BBI5N08 Fan Replacement: passo 9, imagem 3 %32
    • Flip up the locking flap for the ZIF connector.
    • Unplug the connector that is keeping the keyboard connected.
  10. ASUS X552LAV-BBI5N08 Fan Replacement: passo 10, imagem 1 %32 ASUS X552LAV-BBI5N08 Fan Replacement: passo 10, imagem 2 %32 ASUS X552LAV-BBI5N08 Fan Replacement: passo 10, imagem 3 %32
    • Remove keyboard from laptop.
    • Remove the five 4mm screws (with a Tri-wing Y1 screwdriver) that are both connecting the fan and motherboard.
    • Pull out WiFi from below the cooling fan by lifting the edge nearest to the fan and sliding it towards the fan.
  11. ASUS X552LAV-BBI5N08 Fan Replacement: passo 11, imagem 1 %32 ASUS X552LAV-BBI5N08 Fan Replacement: passo 11, imagem 2 %32 ASUS X552LAV-BBI5N08 Fan Replacement: passo 11, imagem 3 %32
    • Lift yellow ZIF connector from the top of the motherboard to remove the connector.
    • Lift up motherboard from bottom edge towards the screen.
  12. ASUS X552LAV-BBI5N08 Fan Replacement: passo 12, imagem 1 %32 ASUS X552LAV-BBI5N08 Fan Replacement: passo 12, imagem 2 %32
    • Unplug the two bundled cable connector from pin sockets below the fan.
    • Remove the motherboard and place on a flat surface.
    • Remove four 4mm screws with a Tri-wing Y1 screwdriver from the CPU.
  13. ASUS X552LAV-BBI5N08 Fan Replacement: passo 13, imagem 1 %32 ASUS X552LAV-BBI5N08 Fan Replacement: passo 13, imagem 2 %32
    • Disconnect bundled cable connector from the motherboard
    • Remove fan part from the motherboard.
  14. ASUS X552LAV-BBI5N08 Fan Replacement: passo 14, imagem 1 %32 ASUS X552LAV-BBI5N08 Fan Replacement: passo 14, imagem 2 %32 ASUS X552LAV-BBI5N08 Fan Replacement: passo 14, imagem 3 %32
    • Remove the black tape from the top of the fan radiator.
    • Remove radiator by tilting it down and pulling it out from the fan.
Conclusão
Jason Vo
Membro desde: 02/15/18
857 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S17-G1, Boczar Spring 2018 Membro de USF Tampa, Team S17-G1, Boczar Spring 2018
USFT-BOCZAR-S18S17G1
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 488
