Ir para o conteúdo principal
ASUS X550LB-DS71 Optical Drive Replacement
O que você precisa
  1. ASUS X550LB-DS71 Optical Drive Replacement, Optical Drive: passo 1, imagem 1 %32 ASUS X550LB-DS71 Optical Drive Replacement, Optical Drive: passo 1, imagem 2 %32 ASUS X550LB-DS71 Optical Drive Replacement, Optical Drive: passo 1, imagem 3 %32
    • Make sure to switch off your laptop before starting.
    • Place the laptop on a flat surface with the bottom side facing upwards.
    • Using the Phillips #1 Screwdriver, remove the four 4mm screws in the back panel.
    • Using both hands, slide the back panel away from the laptop horizontally.
  2. ASUS X550LB-DS71 Optical Drive Replacement: passo 2, imagem 1 %32
    • Using the Phillips #0 Screwdriver, remove the ten 2mm screws at the marked locations.
  3. ASUS X550LB-DS71 Optical Drive Replacement: passo 3, imagem 1 %32 ASUS X550LB-DS71 Optical Drive Replacement: passo 3, imagem 2 %32 ASUS X550LB-DS71 Optical Drive Replacement: passo 3, imagem 3 %32
    • Using the plastic opening tool, open the back cover of the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  4. ASUS X550LB-DS71 Optical Drive Replacement: passo 4, imagem 1 %32 ASUS X550LB-DS71 Optical Drive Replacement: passo 4, imagem 2 %32
    • Using the Phillips #0 Screwdriver, remove the 2mm screw at the marked location.
    • Remove the Optical Drive by sliding it to the right.
Conclusão
Nathan Dyer
Membro desde: 09/25/17
550 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S16-G1, Eyestone Fall 2017 Membro de USF Tampa, Team S16-G1, Eyestone Fall 2017
USFT-EYESTONE-F17S16G1
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 22
Duração total: 2,009
