Introdução
The fan helps get rid of the excess heat in the laptop. A damaged fan can cause overheating and poor performance. This guide explains how to replace it.
O que você precisa
Place the laptop on a flat surface with the bottom side facing upwards.
Using the Phillips #1 Screwdriver, remove the four 4mm screws in the back panel.
Using both hands, slide the back panel away from the laptop horizontally.
Uma outra pessoa concluiu este guia.
