Introdução
Has your wifi stopped working all together and no amount of trouble-shooting, software changes, or driver installations has fixed the issue? It most likely at this point is a faulty hardware issue. In this guide we will show you how to replace the Wifi card altogether. It is a little difficult to do, but with the help of this guide it should be doable. Follow this guy carefully and slowly to be sure of no mistakes or errors to prevent further problems.
O que você precisa
Turn over the laptop on the back panel.
Use the Phillips #0 screwdriver to unscrew all ten screws visible on the back panel. There should be a total of ten screws: (4) four 5.5mm screws and (6) six 10.5mm screws.
Uma outra pessoa concluiu este guia.
