Ir para o conteúdo principal
ASUS X533SA-BHCLN10 LCD Screen Replacement
O que você precisa
Vídeo de Apresentação
  1. ASUS X533SA-BHCLN10 LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32 ASUS X533SA-BHCLN10 LCD Screen Replacement, LCD Screen: passo 1, imagem 2 %32
    • Power off laptop.
    • Flip over the laptop so the model stickers are pointing towards the ceiling, and the back of the laptop is facing you.
  2. ASUS X533SA-BHCLN10 LCD Screen Replacement: passo 2, imagem 1 %32 ASUS X533SA-BHCLN10 LCD Screen Replacement: passo 2, imagem 2 %32 ASUS X533SA-BHCLN10 LCD Screen Replacement: passo 2, imagem 3 %32
    • Carefully insert a plastic opening tool into the top edge of the plastic cover. Slowly run the tool along the top edge to allow several small plastic clips to release.
    • Lift the plastic cover off and set it aside.
  3. ASUS X533SA-BHCLN10 LCD Screen Replacement: passo 3, imagem 1 %32 ASUS X533SA-BHCLN10 LCD Screen Replacement: passo 3, imagem 2 %32 ASUS X533SA-BHCLN10 LCD Screen Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers, remove the (2) two magnetic tabs covering the screws on the screen.
  4. ASUS X533SA-BHCLN10 LCD Screen Replacement: passo 4, imagem 1 %32 ASUS X533SA-BHCLN10 LCD Screen Replacement: passo 4, imagem 2 %32 ASUS X533SA-BHCLN10 LCD Screen Replacement: passo 4, imagem 3 %32
    • Use a JIS #0 screwdriver to remove the two 4.5mm screws.
  5. ASUS X533SA-BHCLN10 LCD Screen Replacement: passo 5, imagem 1 %32 ASUS X533SA-BHCLN10 LCD Screen Replacement: passo 5, imagem 2 %32
    • Insert a plastic opening tool under the edge of the laptop lid.
    • Carefully pop out the sides of the laptop by running the plastic opening tool along the edge.
  6. ASUS X533SA-BHCLN10 LCD Screen Replacement: passo 6, imagem 1 %32 ASUS X533SA-BHCLN10 LCD Screen Replacement: passo 6, imagem 2 %32
    • Use a JIS #0 screwdriver to unscrew the four 3.5mm screws.
  7. ASUS X533SA-BHCLN10 LCD Screen Replacement: passo 7, imagem 1 %32 ASUS X533SA-BHCLN10 LCD Screen Replacement: passo 7, imagem 2 %32 ASUS X533SA-BHCLN10 LCD Screen Replacement: passo 7, imagem 3 %32
    • Carefully lift up the LCD screen.
    • Carefully remove the cable connecting the LCD to the laptop by popping up the white clip on the laptop and sliding the connector out.
Conclusão
Spencer Lee
Membro desde: 11/01/18
268 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S2-G4, Harley Fall 2018 Membro de IUPUI, Team S2-G4, Harley Fall 2018
IUPUI-HARLEY-F18S2G4
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 14
Duração total: 533
