Ir para o conteúdo principal
ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement
O que você precisa
  1. ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement, Palm Rest with Keyboard and Touch Pad: passo 1, imagem 1 %32
    • Use the Phillips #00 screwdriver to remove the seven 90mm screws.
    • Use the Phillips #00 screwdriver to remove the four 50mm screws.
  2. ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: passo 2, imagem 1 %32
    • Next, use the plastic opening tool to carefully pop off the keyboard cover panel.
    • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
  3. ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: passo 3, imagem 1 %32 ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Lift palm rest and unplug keyboard cable and touchpad cable using tweezers. After these two cables have been unplugged you can remove the keyboard cover panel.
  4. ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: passo 4, imagem 1 %32 ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: passo 4, imagem 2 %32
    • Lift Palm Rest away.
    • Replace with new palm rest.
Conclusão
5 outras pessoas executaram este guia.
Michael Morrow
Membro desde: 03/03/15
258 Reputação
Autoria de 1 guia
Equipe
Clemson, Team 14-1, Shirley Winter 2015 Membro de Clemson, Team 14-1, Shirley Winter 2015
CLEM-SHIRLEY-W15S14G1
Membros da 5
Autoria de 5 guias
Um comentário
there is no reason to disassemble the top-half of the laptop.
seanwilson684 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 1,922
