Ir para o conteúdo principal
ASUS X502CA LED Board Replacement
O que você precisa
  1. ASUS X502CA LED Board Replacement, Palm Rest with Keyboard and Touch Pad: passo 1, imagem 1 %32
    • Use the Phillips #00 screwdriver to remove the seven 90mm screws.
    • Use the Phillips #00 screwdriver to remove the four 50mm screws.
  2. ASUS X502CA LED Board Replacement: passo 2, imagem 1 %32
    • Next, use the plastic opening tool to carefully pop off the keyboard cover panel.
    • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
  3. ASUS X502CA LED Board Replacement: passo 3, imagem 1 %32 ASUS X502CA LED Board Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Lift palm rest and unplug keyboard cable and touchpad cable using tweezers. After these two cables have been unplugged you can remove the keyboard cover panel.
  4. ASUS X502CA LED Board Replacement: passo 4, imagem 1 %32 ASUS X502CA LED Board Replacement: passo 4, imagem 2 %32
    • Lift Palm Rest away.
    • Replace with new palm rest.
  5. ASUS X502CA LED Board Replacement, LED Board: passo 5, imagem 1 %32 ASUS X502CA LED Board Replacement, LED Board: passo 5, imagem 2 %32 ASUS X502CA LED Board Replacement, LED Board: passo 5, imagem 3 %32
    • Use the plastic opening tool to flip up the small clamp and pull out the ribbon cable.
  6. ASUS X502CA LED Board Replacement: passo 6, imagem 1 %32 ASUS X502CA LED Board Replacement: passo 6, imagem 2 %32
    • Use 1 or 2 plastic opening tools to push down the small black plastic clips.
    • Pull the board up and out.
Conclusão
Uma outra pessoa concluiu este guia.
Beau Raymond
Membro desde: 11/06/18
103 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team S5-G6, Gulbrandsen Fall 2018 Membro de UMass Dartmouth, Team S5-G6, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G6
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 221
