Ir para o conteúdo principal
ASUS X502CA Fan Replacement
O que você precisa
  1. ASUS X502CA Fan Replacement, Fan: passo 1, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove:
    • Eight 9 mm screws.
    • Four 5 mm screws.
  2. ASUS X502CA Fan Replacement: passo 2, imagem 1 %32
    • Remove the keyboard cover panel by using a plastic opening tool to carefully pop off the clips around the perimeter.
    • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
  3. ASUS X502CA Fan Replacement: passo 3, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • The keyboard cover panel is connected to the motherboard with ribbons; be careful not to damage them.
    • Lift the keyboard cover carefully.
    • Disconnect the keyboard and touch-pad ribbons using tweezers.
  4. ASUS X502CA Fan Replacement: passo 4, imagem 1 %32
    • Remove the keyboard cover panel.
  5. ASUS X502CA Fan Replacement: passo 5, imagem 1 %32
    • Fold up the black plastic arms securing the cables and disconnect them using tweezers or finger nails.
    • If these are not unplugged, the motherboard may shock you.
  6. ASUS X502CA Fan Replacement: passo 6, imagem 1 %32
    • Disconnect the remaining connectors using tweezers or your finger nails.
  7. ASUS X502CA Fan Replacement: passo 7, imagem 1 %32
    • Remove the six 5 mm screws using the Phillips #00 screwdriver.
  8. ASUS X502CA Fan Replacement: passo 8, imagem 1 %32
    • Flip the motherboard over and away from the screen.
  9. ASUS X502CA Fan Replacement: passo 9, imagem 1 %32
    • Remove the two 5 mm screws with a Phillips #00 screwdriver.
  10. ASUS X502CA Fan Replacement: passo 10, imagem 1 %32
    • Unplug the fan's power connector using tweezers or your fingernails.
  11. ASUS X502CA Fan Replacement: passo 11, imagem 1 %32
    • Peel off the marked strip using your fingers.
  12. ASUS X502CA Fan Replacement: passo 12, imagem 1 %32
    • Lift the fan up and away from the motherboard.
Conclusão
6 outras pessoas executaram este guia.
David Conner
Membro desde: 03/03/15
292 Reputação
Autoria de 2 guias
Equipe
Clemson, Team 14-1, Shirley Winter 2015 Membro de Clemson, Team 14-1, Shirley Winter 2015
CLEM-SHIRLEY-W15S14G1
Membros da 5
Autoria de 5 guias
2 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 7,867
