Ir para o conteúdo principal
ASUS X44H-BBR4 Hard Drive Replacement
O que você precisa
  1. ASUS X44H-BBR4 Hard Drive Replacement, Battery: passo 1, imagem 1 %32 ASUS X44H-BBR4 Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Flip the device over.
  2. ASUS X44H-BBR4 Hard Drive Replacement: passo 2, imagem 1 %32 ASUS X44H-BBR4 Hard Drive Replacement: passo 2, imagem 2 %32 ASUS X44H-BBR4 Hard Drive Replacement: passo 2, imagem 3 %32
    • Slide the right lock button to the unlock position.
    • After it is unlocked, a red line will be visible.
  3. ASUS X44H-BBR4 Hard Drive Replacement: passo 3, imagem 1 %32 ASUS X44H-BBR4 Hard Drive Replacement: passo 3, imagem 2 %32
    • Slide the left lock button into the unlock position and hold.
  4. ASUS X44H-BBR4 Hard Drive Replacement: passo 4, imagem 1 %32 ASUS X44H-BBR4 Hard Drive Replacement: passo 4, imagem 2 %32 ASUS X44H-BBR4 Hard Drive Replacement: passo 4, imagem 3 %32
    • While holding the left lock button in the unlock position, push the battery from the center away from you.
  5. ASUS X44H-BBR4 Hard Drive Replacement, Hard Drive: passo 5, imagem 1 %32 ASUS X44H-BBR4 Hard Drive Replacement, Hard Drive: passo 5, imagem 2 %32
    • Remove the two 9 mm Phillips head screws with the PH0 bit indicated by the red circles in the picture.
  6. ASUS X44H-BBR4 Hard Drive Replacement: passo 6, imagem 1 %32 ASUS X44H-BBR4 Hard Drive Replacement: passo 6, imagem 2 %32
    • Once the screws are removed, slide the back panel away from the computer.
  7. ASUS X44H-BBR4 Hard Drive Replacement: passo 7, imagem 1 %32
    • Remove the 9mm Phillips head screw in the left bottom corner of the hard drive with the PH0 bit.
  8. ASUS X44H-BBR4 Hard Drive Replacement: passo 8, imagem 1 %32 ASUS X44H-BBR4 Hard Drive Replacement: passo 8, imagem 2 %32
    • Slide the hard drive to the left, unlocking it from its default position.
  9. ASUS X44H-BBR4 Hard Drive Replacement: passo 9, imagem 1 %32 ASUS X44H-BBR4 Hard Drive Replacement: passo 9, imagem 2 %32
    • Pull the hard drive upwards and take it out of its position.
  10. ASUS X44H-BBR4 Hard Drive Replacement: passo 10, imagem 1 %32 ASUS X44H-BBR4 Hard Drive Replacement: passo 10, imagem 2 %32 ASUS X44H-BBR4 Hard Drive Replacement: passo 10, imagem 3 %32
    • Remove two 3mm Phillips head screws, one located on each side of the metal casing holding the hard drive using the PH0 bit.
  11. ASUS X44H-BBR4 Hard Drive Replacement: passo 11, imagem 1 %32
    • Pull upwards on the metal casing and it will come off.
Conclusão
Uma outra pessoa concluiu este guia.
Devaj Ramsamooj
Membro desde: 10/21/15
824 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 4-3, Catania Fall 2015 Membro de UMass Dartmouth, Team 4-3, Catania Fall 2015
UMASSD-CATANIA-F15S4G3
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 1,233
