Introdução
Use this guide to help you replace a broken or damaged fan that may be causing overheating issues and other problems with your laptop. Don't forget to keep track of all your screws.
O que você precisa
Remove the two 9 mm Phillips head screws with the PH0 bit indicated by the red circles in the picture.
Lift up the black lock holding the ribbon.
Using the blue tab, pull out the ribbon.
Remove the black piece of tape located on each side of the fan and vent, connecting the two components.
Uma outra pessoa concluiu este guia.
