Introdução
The screen is one of the most important parts of a laptop, as you won't be able to see anything you're doing without it, which is kind of the point. The disassembly isn't too complicated, there's just a lot of screws that need to be removed.
O que você precisa
Using a Spudger, gently pry up the keyboard.
Use the Phillips #0 screwdriver to remove the two screws on the back of the laptop.
Uma outra pessoa concluiu este guia.
