Ir para o conteúdo principal
ASUS X42J Laptop Fan Replacement
O que você precisa
  1. ASUS X42J Laptop Fan Replacement, Keyboard: passo 1, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Metal Spudger
    $2.99
    Comprar
    • Make sure your device is unplugged and turned off before proceeding.
    • Using a Spudger, gently pry up the keyboard.
  2. ASUS X42J Laptop Fan Replacement: passo 2, imagem 1 %32 ASUS X42J Laptop Fan Replacement: passo 2, imagem 2 %32
    Nylon Tipped Tweezers
    Comprar
    • Rotate the keyboard to face downward.
    • Pull out the blue wiring connection. Use tweezers to make it easier to remove.
  3. ASUS X42J Laptop Fan Replacement, Disk Drive: passo 3, imagem 1 %32
    • Use the Phillips #0 screwdriver to remove the two screws on the back of the laptop.
  4. ASUS X42J Laptop Fan Replacement: passo 4, imagem 1 %32
    • Slide the disk drive out of the device.
  5. ASUS X42J Laptop Fan Replacement, Motherboard: passo 5, imagem 1 %32 ASUS X42J Laptop Fan Replacement, Motherboard: passo 5, imagem 2 %32 ASUS X42J Laptop Fan Replacement, Motherboard: passo 5, imagem 3 %32
    • Remove all screws located on the bottom plate of the laptop, beginning with the three located underneath the disc drive.
  6. ASUS X42J Laptop Fan Replacement: passo 6, imagem 1 %32 ASUS X42J Laptop Fan Replacement: passo 6, imagem 2 %32
    • Rotate the laptop until it is sitting face up and extract all screws exposed by removing the keyboard.
  7. ASUS X42J Laptop Fan Replacement: passo 7, imagem 1 %32 ASUS X42J Laptop Fan Replacement: passo 7, imagem 2 %32
    Metal Spudger
    $2.99
    Comprar
    • Pull up on the front panel using the spudger until the front panel separates from the bottom panel.
  8. ASUS X42J Laptop Fan Replacement: passo 8, imagem 1 %32
    • Unscrew and remove the marked screws.
  9. ASUS X42J Laptop Fan Replacement: passo 9, imagem 1 %32
    • Separate the connectors.
  10. ASUS X42J Laptop Fan Replacement: passo 10, imagem 1 %32 ASUS X42J Laptop Fan Replacement: passo 10, imagem 2 %32
    • Remove the motherboard from the device.
  11. ASUS X42J Laptop Fan Replacement, Fan: passo 11, imagem 1 %32
    • Unscrew the six screws using the Phillips #0 Screwdriver.
  12. ASUS X42J Laptop Fan Replacement: passo 12, imagem 1 %32
    • Unplug the fan's wires from the motherboard.
  13. ASUS X42J Laptop Fan Replacement: passo 13, imagem 1 %32 ASUS X42J Laptop Fan Replacement: passo 13, imagem 2 %32
    • Remove the fan from the motherboard.
Conclusão
Ryan Pritchard
Membro desde: 09/21/18
105 Reputação
Autoria de 1 guia
Um comentário
First step is wrong; attempting to prise out the keyboard will damage it. First step should be to remove the screws which hold in the keyboard.
Kate Gregory - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 575
