Ir para o conteúdo principal
ASUS Vivobook S500CA Battery Replacement
O que você precisa
  1. ASUS Vivobook S500CA Battery Replacement, Battery: passo 1, imagem 1 %32
    • Turn the device over to where the back plate is facing up.
  2. ASUS Vivobook S500CA Battery Replacement: passo 2, imagem 1 %32
    • Use a Philips Head PH1 screwdriver to remove 10 screws (3 1cm screws and 7 .5cm screws) around the perimeter of the back plate.
    • Place screws where they cannot be lost as they will be used to replace the back plate.
  3. ASUS Vivobook S500CA Battery Replacement: passo 3, imagem 1 %32
    • Remove the back plate by lifting it straight up.
  4. ASUS Vivobook S500CA Battery Replacement: passo 4, imagem 1 %32
    • Remove 9 (.5 cm) phillips screws around the edge of the battery.
  5. ASUS Vivobook S500CA Battery Replacement: passo 5, imagem 1 %32
    • Lift up the battery to reveal the battery terminal.
  6. ASUS Vivobook S500CA Battery Replacement: passo 6, imagem 1 %32
    • Unclip the battery terminal by prying straight up on the sides of the connector to release the clip.
Conclusão
Deric Huffman
Membro desde: 01/17/17
101 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 16
Duração total: 6,043
