Ir para o conteúdo principal
ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement
O que você precisa
  1. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement, Back Case Housing: passo 1, imagem 1 %32
    • Remove all ten 6mm Phillips #1 screws from the bottom of the computer chassis.
  2. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement: passo 2, imagem 1 %32
    • Carefully pry open the back cover from the laptop and place it to the side.
  3. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement, Memory Card: passo 3, imagem 1 %32 ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement, Memory Card: passo 3, imagem 2 %32
    • Lift the perforated metal cover up from the motherboard to expose the memory cards.
  4. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement: passo 4, imagem 1 %32 ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement: passo 4, imagem 2 %32
    • Once the cover is removed the RAM will be accessible.
    • Use your fingertips to pry out the metal guards outlining both of the sides of the memory card.
    • The RAM stick should then pop up to rest at an angle to the motherboard.
  5. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement: passo 5, imagem 1 %32
    • Using your fingertips, slide the memory card out from the plastic housing and remove it from the board.
    • Be sure to remove the card at the same angle at which it rests to avoid damaging the card or the contacts of the slot.
Conclusão
Mark Fanelli
Membro desde: 04/09/19
97 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S1-G2, Hovde Spring 2019 Membro de IUPUI, Team S1-G2, Hovde Spring 2019
IUPUI-HOVDE-S19S1G2
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 440
