Ir para o conteúdo principal
ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement
O que você precisa
  1. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement, Hard Drive: passo 1, imagem 2 %32 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement, Hard Drive: passo 1, imagem 3 %32
    • Flip the laptop onto its backside.
    • Use a Phillips #00 screwdriver to remove the nine 1.2 mm Phillips #00 screws screws attached to the laptop backing.
  2. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: passo 2, imagem 1 %32 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: passo 2, imagem 2 %32
    • Remove the laptop backing with a prying tool. Use the prying tool between the keyboard and bottom grooves.
    • Start prying from the center of the laptop and work your way around the edges of the laptop to remove the keyboard panel.
    • It is recommended to use a plastic prying tool versus a metal prying tool as it could scratch your laptop.
  3. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: passo 3, imagem 1 %32 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: passo 3, imagem 2 %32
    • Separate the laptop keyboard from the laptop backing.
    • Carefully remove the keyboard connector from the motherboard.
  4. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: passo 4, imagem 1 %32 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: passo 4, imagem 2 %32
    • Remove the two 3 mm screws attached to the laptop's hard drive metal cage using the Phillips #00 screwdriver.
    • Once the screws have been removed, gently disconnect the hard drive by pulling the hard drive away from the integrated SATA port.
  5. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: passo 5, imagem 1 %32 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: passo 5, imagem 2 %32
    • Remove the four 3 mm screws attached to hard drive metal cage using the Phillips #00 screwdriver.
    • Remove the hard drive from the bracket.
Conclusão
3 outras pessoas executaram este guia.
Um comentário
I replaced the original sata into a ssd but it doesnt boot to windows. It gets stuck in bios. The ssd has an os already. It appears in the storage section but not in the boot list. I have already tried to boot the ssd to my computer and it works.
Christusjohn Leoncio L Salvani - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 19
Últimos 30 dias: 71
Ao todo: 2,188
