Introdução
If your ASUS VivoBook S400C has an issue regarding wifi after running through general troubleshooting or you want to replace the wifi card with a different model, follow this guide to replace the wifi card.
O que você precisa
Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
Using a spudger, lift up the plug connecting the battery to the motherboard.
Quase terminado!
Conclusão
