Ir para o conteúdo principal
ASUS VivoBook S400C Hard Drive Replacement
O que você precisa
  1. ASUS VivoBook S400C Hard Drive Replacement, Remove the Bottom Cover: passo 1, imagem 1 %32
    • Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
  2. ASUS VivoBook S400C Hard Drive Replacement: passo 2, imagem 1 %32 ASUS VivoBook S400C Hard Drive Replacement: passo 2, imagem 2 %32
    • Use a spudger or your fingers to go around and lift the edges and release the back panel.
  3. ASUS VivoBook S400C Hard Drive Replacement, Disconnect the Battery: passo 3, imagem 1 %32
    • Using a spudger, lift up the plug connecting the battery to the motherboard.
  4. ASUS VivoBook S400C Hard Drive Replacement, Battery: passo 4, imagem 1 %32
    • With a Phillips #0 screwdriver, remove the four 5.7 mm screws holding the battery to the laptop.
  5. ASUS VivoBook S400C Hard Drive Replacement: passo 5, imagem 1 %32
    • Carefully lift the battery up and out of the device.
  6. ASUS VivoBook S400C Hard Drive Replacement, Hard Drive: passo 6, imagem 1 %32
    • Remove the three Phillips #0 screws holding the the hard drive in place:
    • Two 3.8 mm screws.
    • One 5.7 mm screw.
  7. ASUS VivoBook S400C Hard Drive Replacement: passo 7, imagem 1 %32
    • Pull left and lift out the hard drive.
Conclusão
Tiana Curry
Membro desde: 10/18/19
85 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 25
Duração total: 2,071
