Ir para o conteúdo principal
ASUS VivoBook Flip TP501U Keyboard Panel Replacement
O que você precisa
  1. ASUS VivoBook Flip TP501U Keyboard Panel Replacement, Keyboard Panel: passo 1, imagem 1 %32 ASUS VivoBook Flip TP501U Keyboard Panel Replacement, Keyboard Panel: passo 1, imagem 2 %32
    • Open the laptop until it is flat and lay it screen down.
    • Remove eight 9.6mm Phillips #00 screws from the bottom of the laptop.
    • Remove two 4.8mm Phillips from the corners of the device.
  2. ASUS VivoBook Flip TP501U Keyboard Panel Replacement: passo 2, imagem 1 %32
    • Turn the device face up.
    • Use the plastic Opening Pick to separate the keyboard panel from the chassis that was just unscrewed.
    • Pull the panel away from the chassis CAREFULLY, as there are ribbon cables attached between the keyboard and internal electronics.
  3. ASUS VivoBook Flip TP501U Keyboard Panel Replacement: passo 3, imagem 1 %32
    • With the keyboard panel pulled up, detach the two ribbon cables from the motherboard using the blue tabs on the cables.
    • Remove the keyboard panel completely.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 17
Duração total: 929
