Ir para o conteúdo principal
ASUS U57A-BBL4 Front Panel Assembly Replacement
O que você precisa
  1. ASUS U57A-BBL4 Front Panel Assembly Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the laptop is completely shut down to avoid data complications.
    • Hold the left lock switch towards the left to the unlock option.
  2. ASUS U57A-BBL4 Front Panel Assembly Replacement: passo 2, imagem 1 %32
    • Toggle the right lock switch to the unlock option.
  3. ASUS U57A-BBL4 Front Panel Assembly Replacement: passo 3, imagem 1 %32
    • Gently slide the battery out while still holding the left unlock switch.
  4. ASUS U57A-BBL4 Front Panel Assembly Replacement, Front Panel Assembly: passo 4, imagem 1 %32 ASUS U57A-BBL4 Front Panel Assembly Replacement, Front Panel Assembly: passo 4, imagem 2 %32
    • Remove the two 2 mm Phillips head screws on each side on the bottom using PH00 screw driver.
    • Remove the one 2 mm screw underneath the black cover in the middle using the same screw driver.
  5. ASUS U57A-BBL4 Front Panel Assembly Replacement: passo 5, imagem 1 %32
    • Remove the RAM by lifting up with your fingers and sliding it out towards you.
  6. ASUS U57A-BBL4 Front Panel Assembly Replacement: passo 6, imagem 1 %32
    • Remove the three 2 mm Phillips head screws on the hard drive using PH00 screw driver.
    • Remove the remaining seven 1.8 mm Phillips head screws using the same screw driver.
  7. ASUS U57A-BBL4 Front Panel Assembly Replacement: passo 7, imagem 1 %32 ASUS U57A-BBL4 Front Panel Assembly Replacement: passo 7, imagem 2 %32
    • Remove the hard drive by sliding it to the left and lifting up.
  8. ASUS U57A-BBL4 Front Panel Assembly Replacement: passo 8, imagem 1 %32 ASUS U57A-BBL4 Front Panel Assembly Replacement: passo 8, imagem 2 %32
    • Remove the six 2 mm Phillips head screws on the top edge of the laptop using PH00 screw driver.
    • Flip the laptop right-side up and open the screen.
  9. ASUS U57A-BBL4 Front Panel Assembly Replacement: passo 9, imagem 1 %32 ASUS U57A-BBL4 Front Panel Assembly Replacement: passo 9, imagem 2 %32 ASUS U57A-BBL4 Front Panel Assembly Replacement: passo 9, imagem 3 %32
    • Starting in a corner of the keyboard, pry the keyboard from the laptop using a plastic opening tool.
    • Remove the ribbon cable on the bottom of the keyboard by lifting up on the tape and pulling up.
    • The front panel is now loose from the laptop.
Conclusão
Isabella Bernardi
Membro desde: 10/18/17
671 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team S2-G4, Julie Fall 2017 Membro de UMass Dartmouth, Team S2-G4, Julie Fall 2017
UMASSD-JULIE-F17S2G4
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 184
