Ir para o conteúdo principal
ASUS U57A-BBL4 Fan Replacement
O que você precisa
  1. ASUS U57A-BBL4 Fan Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the laptop is completely shut down to avoid data complications.
    • Hold the left lock switch towards the left to the unlock option.
  2. ASUS U57A-BBL4 Fan Replacement: passo 2, imagem 1 %32
    • Toggle the right lock switch to the unlock option.
  3. ASUS U57A-BBL4 Fan Replacement: passo 3, imagem 1 %32
    • Gently slide the battery out while still holding the left unlock switch.
  4. ASUS U57A-BBL4 Fan Replacement, Front Panel Assembly: passo 4, imagem 1 %32 ASUS U57A-BBL4 Fan Replacement, Front Panel Assembly: passo 4, imagem 2 %32
    • Remove the two 2 mm Phillips head screws on each side on the bottom using PH00 screw driver.
    • Remove the one 2 mm screw underneath the black cover in the middle using the same screw driver.
  5. ASUS U57A-BBL4 Fan Replacement: passo 5, imagem 1 %32
    • Remove the RAM by lifting up with your fingers and sliding it out towards you.
  6. ASUS U57A-BBL4 Fan Replacement: passo 6, imagem 1 %32
    • Remove the three 2 mm Phillips head screws on the hard drive using PH00 screw driver.
    • Remove the remaining seven 1.8 mm Phillips head screws using the same screw driver.
  7. ASUS U57A-BBL4 Fan Replacement: passo 7, imagem 1 %32 ASUS U57A-BBL4 Fan Replacement: passo 7, imagem 2 %32
    • Remove the hard drive by sliding it to the left and lifting up.
  8. ASUS U57A-BBL4 Fan Replacement: passo 8, imagem 1 %32 ASUS U57A-BBL4 Fan Replacement: passo 8, imagem 2 %32
    • Remove the six 2 mm Phillips head screws on the top edge of the laptop using PH00 screw driver.
    • Flip the laptop right-side up and open the screen.
  9. ASUS U57A-BBL4 Fan Replacement: passo 9, imagem 1 %32 ASUS U57A-BBL4 Fan Replacement: passo 9, imagem 2 %32 ASUS U57A-BBL4 Fan Replacement: passo 9, imagem 3 %32
    • Starting in a corner of the keyboard, pry the keyboard from the laptop using a plastic opening tool.
    • Remove the ribbon cable on the bottom of the keyboard by lifting up on the tape and pulling up.
    • The front panel is now loose from the laptop.
  10. ASUS U57A-BBL4 Fan Replacement, Optical Drive: passo 10, imagem 1 %32
    • Slide the optical drive out. It should easily come out.
  11. ASUS U57A-BBL4 Fan Replacement, Motherboard: passo 11, imagem 1 %32
    • Remove the four 2 mm Phillips head screws from the top of the motherboard and fan using PH #1 screwdriver.
  12. ASUS U57A-BBL4 Fan Replacement: passo 12, imagem 1 %32 ASUS U57A-BBL4 Fan Replacement: passo 12, imagem 2 %32
    • Remove the blue cable on the bottom right by lifting up on the tab and pulling the cable out.
  13. ASUS U57A-BBL4 Fan Replacement: passo 13, imagem 1 %32 ASUS U57A-BBL4 Fan Replacement: passo 13, imagem 2 %32 ASUS U57A-BBL4 Fan Replacement: passo 13, imagem 3 %32
    • Peel off the black and yellow tape attaching the fan to the base.
    • Peel the tape off the yellow cable and pull out to remove the cable.
    • Remove the small black, white and red cable next to the yellow cable at the top.
  14. ASUS U57A-BBL4 Fan Replacement: passo 14, imagem 1 %32
    • Carefully and slowly lift up the motherboard from the base and remove the red and black cable underneath the motherboard in the top left corner near the fan.
    • The motherboard and fan are still attached to each other, but are loose from the base.
  15. ASUS U57A-BBL4 Fan Replacement: passo 15, imagem 1 %32
    • Remove the four 2 mm Phillips head screws surrounding the copper rod using PH1 screw driver.
  16. ASUS U57A-BBL4 Fan Replacement: passo 16, imagem 1 %32
    • Remove the red, blue, black and yellow cable attaching the fan and motherboard together with your fingers.
    • Now the motherboard and fan are completely separate from each other.
  17. ASUS U57A-BBL4 Fan Replacement, Fan: passo 17, imagem 1 %32
    • Slide the fan out from the ridged metal component.
Conclusão
Isabella Bernardi
Membro desde: 10/18/17
671 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team S2-G4, Julie Fall 2017 Membro de UMass Dartmouth, Team S2-G4, Julie Fall 2017
UMASSD-JULIE-F17S2G4
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 331
