Ir para o conteúdo principal
ASUS U57A-BBL4 Display Assembly Replacement
O que você precisa
  1. ASUS U57A-BBL4 Display Assembly Replacement, Display Assembly: passo 1, imagem 1 %32 ASUS U57A-BBL4 Display Assembly Replacement, Display Assembly: passo 1, imagem 2 %32
    • Carefully pry the two rubber covers at the bottom of the screen off with a metal sprudger.
  2. ASUS U57A-BBL4 Display Assembly Replacement: passo 2, imagem 1 %32
    • Remove the two 1.84 mm Phillips head screws at the bottom of the screen using PH00 screw driver.
  3. ASUS U57A-BBL4 Display Assembly Replacement: passo 3, imagem 1 %32
    • Starting from one of the corners, use your fingers to pry the bezel from the screen.
    • There is a popping sound when the bezel is loosened from the screen.
  4. ASUS U57A-BBL4 Display Assembly Replacement: passo 4, imagem 1 %32 ASUS U57A-BBL4 Display Assembly Replacement: passo 4, imagem 2 %32 ASUS U57A-BBL4 Display Assembly Replacement: passo 4, imagem 3 %32
    • Remove the top two 2 mm Phillips head screws.
    • Remove the four 2 mm Phillips head screws on the bottom.
    • Remove the eight 2 mm Phillips head screws on the sides of the screen. There are four on each side.
    • There are 14 screws in total: two on the top, four on the bottom, and four on each side. Use PH00 screw-driver for removing all 14 screws.
  5. ASUS U57A-BBL4 Display Assembly Replacement: passo 5, imagem 1 %32 ASUS U57A-BBL4 Display Assembly Replacement: passo 5, imagem 2 %32
    • Don't tear off the bottom of the screen or you might damage the connector cable.
    • Carefully lower the screen from the casing with your fingers, making sure to keep the bottom intact and lay it face down on the keyboard.
  6. ASUS U57A-BBL4 Display Assembly Replacement: passo 6, imagem 1 %32 ASUS U57A-BBL4 Display Assembly Replacement: passo 6, imagem 2 %32
    • Disconnect the connector cable at the bottom by loosening the adhesive tape and lifting up.
    • Gently slide the cable out of the ridges to free the screen from the casing.
Conclusão
Uma outra pessoa concluiu este guia.
Isabella Bernardi
Membro desde: 10/18/17
671 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team S2-G4, Julie Fall 2017 Membro de UMass Dartmouth, Team S2-G4, Julie Fall 2017
UMASSD-JULIE-F17S2G4
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 254
