Ir para o conteúdo principal
ASUS U52F-BBG6 Keyboard Replacement
O que você precisa
  1. ASUS U52F-BBG6 Keyboard Replacement, Back Cover: passo 1, imagem 1 %32 ASUS U52F-BBG6 Keyboard Replacement, Back Cover: passo 1, imagem 2 %32
    • Flip the laptop over to the back.
    • Slide the right latch to unlock, then simultaneously slide the left latch outward while pulling the battery out.
  2. ASUS U52F-BBG6 Keyboard Replacement: passo 2, imagem 1 %32 ASUS U52F-BBG6 Keyboard Replacement: passo 2, imagem 2 %32 ASUS U52F-BBG6 Keyboard Replacement: passo 2, imagem 3 %32
    • Unscrew all twelve 3mm Phillips screws with the J1 screwdriver.
    • Unscrew two 3mm Phillips screws on the black panel using the PH0 screwdriver.
    • Lift the black panel upward by inserting your fingernail in the space provided.
  3. ASUS U52F-BBG6 Keyboard Replacement: passo 3, imagem 1 %32 ASUS U52F-BBG6 Keyboard Replacement: passo 3, imagem 2 %32 ASUS U52F-BBG6 Keyboard Replacement: passo 3, imagem 3 %32
    • In the RAM and hard drive compartment, unscrew the four 3mm Phillips screws using the J1 screwdriver.
    • Gently pull out the hard drive.
  4. ASUS U52F-BBG6 Keyboard Replacement: passo 4, imagem 1 %32 ASUS U52F-BBG6 Keyboard Replacement: passo 4, imagem 2 %32
    • Unscrew six 3mm Phillips screws in the RAM and hard drive compartment with the J1 screwdriver.
  5. ASUS U52F-BBG6 Keyboard Replacement: passo 5, imagem 1 %32
    • Pull the CD drive outward with your left hand.
  6. ASUS U52F-BBG6 Keyboard Replacement: passo 6, imagem 1 %32 ASUS U52F-BBG6 Keyboard Replacement: passo 6, imagem 2 %32
    • Insert and gently twist the flat metal spudger between the keyboard assembly and the bottom plastic cover so that a small seam is opened.
    • Put in the metal spudger in the seam to hold its place while twisting and levering the flat metal spudger along the whole keyboard.
    • Be careful not to hit any of the internals with the metal spudger. The regular black nylon spudger should be used whenever possible, especially around batteries or sensitive internal components.
    • You will need add a lot of pressure to open the laptop. Expect to hear snaps as the clips holding the two pieces are released.
    • Slowly pry off the back
  7. ASUS U52F-BBG6 Keyboard Replacement, Keyboard: passo 7, imagem 1 %32 ASUS U52F-BBG6 Keyboard Replacement, Keyboard: passo 7, imagem 2 %32
    • Unlatch the clip attaching the white flattened flexible cord with a blue tip to the circuit board with your thumb.
    • Pull out the white flattened cord.
  8. ASUS U52F-BBG6 Keyboard Replacement: passo 8, imagem 1 %32
    • Pull back yellow tape attaching the metal colored flexible flattened cord to the circuit board.
    • Lift up the latch at the end of the cord.
    • Pull out the cord to release the keyboard.
Conclusão
Uma outra pessoa concluiu este guia.
Ashley DeHuff
Membro desde: 09/15/16
852 Reputação
Autoria de 8 guias
Equipe
CSU Fullerton, Team 1-3, Bruce Fall 2016 Membro de CSU Fullerton, Team 1-3, Bruce Fall 2016
CSUF-BRUCE-F16S1G3
Membros da 4
Autoria de 9 guias
Um comentário
How do you remove the keyboard from the palm rest is what I'd like to know...what a goofy design
love4talent - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 793
