Pular para o conteúdo principal
Introdução
This guide will inform you on how to replace your hard drive. This replacement will be very easy as there are only a few screws that need to be taken out during this guide to access and remove the hard drive.
Peças
Nenhum componente especificado.
  1. Turn the laptop over to the back. Unscrew the two 3mm Phillips screws using a PH0 screwdriver.
    • Turn the laptop over to the back.
    • Unscrew the two 3mm Phillips screws using a PH0 screwdriver.
    • Lift the small black panel upward by putting your fingernail in the provided slot.
  2. PC Laptop Batteries
    An easy fix for a big power boost.
    Comprar agora
    PC Laptop Batteries
    Comprar agora
  3. Use the J1 screwdriver to unscrew the four 3mm Phillips screws on the hard drive.
    • Use the J1 screwdriver to unscrew the four 3mm Phillips screws on the hard drive.
  4. Slowly pull the hard drive upward with your finger and thumb.
    • Slowly pull the hard drive upward with your finger and thumb.
Conclusão
Ashley DeHuff
Membro desde: 15-09-2016
828 reputação
8 Guias de autoria
Equipe
CSU Fullerton, Team 1-3, Bruce Fall 2016 Membro de CSU Fullerton, Team 1-3, Bruce Fall 2016
CSUF-BRUCE-F16S1G3
4 Membros
9 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Todo: 445
