Ir para o conteúdo principal
ASUS U52F-BBG6 Camera Replacement
O que você precisa
  1. ASUS U52F-BBG6 Camera Replacement, Camera: passo 1, imagem 1 %32 ASUS U52F-BBG6 Camera Replacement, Camera: passo 1, imagem 2 %32
    • Scrape off the black circle rubber cushions with your index finger at the bottom frame of the screen.
    • The cushions may no longer be adherent and a bit of glue may be needed to reattach them.
    • Unscrew the two 3mm Phillips screws on the bottom of the frame with the J1 screwdriver.
    • The two 3mm Phillips screws are hidden behind the cushions.
  2. ASUS U52F-BBG6 Camera Replacement: passo 2, imagem 1 %32 ASUS U52F-BBG6 Camera Replacement: passo 2, imagem 2 %32
    • Insert the plastic opening tool into the crack where the plastic of the screen's frame meets the shell at the top.
    • Be careful not to scratch the screen with the opening tool.
    • Gently twist and slide the tool to open it. The plastic will snap as the frame is released.
    • The snaps that hold the frame to the shell are fragile.
    • Continue to pry with the opening tool or use your fingers until the top portion of the frame releases.
  3. ASUS U52F-BBG6 Camera Replacement: passo 3, imagem 1 %32 ASUS U52F-BBG6 Camera Replacement: passo 3, imagem 2 %32
    • Pull the screen frame towards you so that the seam between the frame and the bottom of the screen is opened.
    • Insert the opening tool into the seam.
    • Peel the metallic strip with your finger and thumb until it's fully off.
    • Place the remaining frame down on the keyboard.
  4. ASUS U52F-BBG6 Camera Replacement: passo 4, imagem 1 %32 ASUS U52F-BBG6 Camera Replacement: passo 4, imagem 2 %32
    • Use the pointed side of the black spudger to remove the metallic stickers by the circuit board of the camera above the screen.
    • Do not remove the sticker completely.
  5. ASUS U52F-BBG6 Camera Replacement: passo 5, imagem 1 %32 ASUS U52F-BBG6 Camera Replacement: passo 5, imagem 2 %32
    • Carefully lift the camera's circuit board by using the flat side of the spudger.
    • The adherent on the camera's circuit board is very sticky.
  6. ASUS U52F-BBG6 Camera Replacement: passo 6, imagem 1 %32 ASUS U52F-BBG6 Camera Replacement: passo 6, imagem 2 %32
    • Holding the camera's circuit board with your right hand, use your left index finger and thumb to unplug the micro white hook from the camera.
    • The micro white hook is fragile.
Conclusão
Uma outra pessoa concluiu este guia.
Ashley DeHuff
Membro desde: 09/15/16
852 Reputação
Autoria de 8 guias
Equipe
CSU Fullerton, Team 1-3, Bruce Fall 2016 Membro de CSU Fullerton, Team 1-3, Bruce Fall 2016
CSUF-BRUCE-F16S1G3
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 253
