Ir para o conteúdo principal
ASUS U46E-RAL7 Audio Board Replacement
O que você precisa
  1. ASUS U46E-RAL7 Audio Board Replacement, ASUS U46E-RAL7 Back Panel Removal Guide: passo 1, imagem 1 %32
    • Remove two (2) 9mm x 4mm screws from the back panel with the size 0 Phillips head screwdriver.
    • Remove two (2) 7mm x 4mm screws from the back panel with the size 0 Phillips head screwdriver.
    • Remove six (6) 7mm x 4mm screws with the size 0 Phillips head screwdriver.
    • Remove three (3) 3mm x 3mm screws with the size 0 Phillips head screwdriver.
    • Remove one (1) 4mm x 4mm screws with the size 0 Phillips head screwdriver.
  2. ASUS U46E-RAL7 Audio Board Replacement: passo 2, imagem 1 %32 ASUS U46E-RAL7 Audio Board Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the rubber caps (4) with the tweezers. If the rubber caps are not removed easily, pull gently. The caps are glued down.
    • Remove four (4) 7mm x 4mm screws with the size 0 Phillips head screwdriver.
  3. ASUS U46E-RAL7 Audio Board Replacement: passo 3, imagem 1 %32 ASUS U46E-RAL7 Audio Board Replacement: passo 3, imagem 2 %32 ASUS U46E-RAL7 Audio Board Replacement: passo 3, imagem 3 %32
    • Remove the L shaped panel with the plastic opening tool by inserting it into the indent along the USB port side of the laptop.
    • Push down gently on the plastic opening tool until part of the panel pops up.
    • Use your fingers to pop the panel off.
  4. ASUS U46E-RAL7 Audio Board Replacement: passo 4, imagem 1 %32
    • Remove three (3) 5mm x 4mm screws with the size 0 Phillips head screwdriver.
    • Remove one (1) 4mm x 4mm (closest to the battery) screw with the size 0 Phillips head screwdriver.
  5. ASUS U46E-RAL7 Audio Board Replacement: passo 5, imagem 1 %32 ASUS U46E-RAL7 Audio Board Replacement: passo 5, imagem 2 %32 ASUS U46E-RAL7 Audio Board Replacement: passo 5, imagem 3 %32
    • Remove the CD ROM drive by inserting the plastic opening tool between the drive and the laptop's side.
    • Push down gently to eject the drive.
    • Pull the drive straight out to remove the part from the laptop.
  6. ASUS U46E-RAL7 Audio Board Replacement: passo 6, imagem 1 %32
  7. ASUS U46E-RAL7 Audio Board Replacement: passo 7, imagem 1 %32 ASUS U46E-RAL7 Audio Board Replacement: passo 7, imagem 2 %32 ASUS U46E-RAL7 Audio Board Replacement: passo 7, imagem 3 %32
    • Flip the device so that the laptop will open away from you to remove the hinge cover behind the screen.
    • Place index fingers underneath the hinge cover and gently pull up.
    • The cover will pop off easily with a click.
    • Remove five (5) 5mm x 4mm screws from the hinge compartments of the device with the size 0 phillips head screwdriver.
  8. ASUS U46E-RAL7 Audio Board Replacement: passo 8, imagem 1 %32 ASUS U46E-RAL7 Audio Board Replacement: passo 8, imagem 2 %32 ASUS U46E-RAL7 Audio Board Replacement: passo 8, imagem 3 %32
    • Open the screen.
    • Carefully lift the keyboard panel. The keyboard will be attached to the motherboard by two ribbons.
    • To disconnect the ribbons, use your fingernails to push down gently on the protruding plastic at the base of the connector. There is a soft click and ribbon releases. Repeat for the other ribbon.
  9. ASUS U46E-RAL7 Audio Board Replacement: passo 9, imagem 1 %32 ASUS U46E-RAL7 Audio Board Replacement: passo 9, imagem 2 %32
    • Remove the keyboard from the computer to reveal the motherboard.
  10. ASUS U46E-RAL7 Audio Board Replacement, Audio Board: passo 10, imagem 1 %32
    • Remove one (1) 5mm x 4mm screw with the size 0 Phillips head screwdriver.
  11. ASUS U46E-RAL7 Audio Board Replacement: passo 11, imagem 1 %32 ASUS U46E-RAL7 Audio Board Replacement: passo 11, imagem 2 %32 ASUS U46E-RAL7 Audio Board Replacement: passo 11, imagem 3 %32
    • Pull up on the black ribbon connection on the audio board. The board will lift out of the device casting.
  12. ASUS U46E-RAL7 Audio Board Replacement: passo 12, imagem 1 %32 ASUS U46E-RAL7 Audio Board Replacement: passo 12, imagem 2 %32
    • Using both hands pull the audio board out by pulling towards the center of the device and then up to remove.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 247
