Ir para o conteúdo principal
ASUS U30SD-XA1 RAM Replacement
O que você precisa
  1. ASUS U30SD-XA1 RAM Replacement, RAM: passo 1, imagem 1 %32
    • Before removing the RAM, shut down your laptop and unplug the power adapter.
    • Turn the laptop over onto a flat surface.
  2. ASUS U30SD-XA1 RAM Replacement: passo 2, imagem 1 %32
    • At the top center on the back of the device, you will see a small square panel.
    • Use a Phillips screwdriver to remove two screws located on the panel.
  3. ASUS U30SD-XA1 RAM Replacement: passo 3, imagem 1 %32 ASUS U30SD-XA1 RAM Replacement: passo 3, imagem 2 %32
    • Ground yourself from electrostatic discharge by touching any metal objects or use your anti-static gloves.
    • System memories are very sensitive to static electricity.
    • Push apart the latches on either side of the slot that hold the RAM in place, but gently.
    • Use firm pressure as needed. You will hear the RAM pop out of the slot.
    • Take the RAM stick out carefully, and set it aside on an anti-static surface.
  4. ASUS U30SD-XA1 RAM Replacement: passo 4, imagem 1 %32
    • To replace the RAM, take and hold the new RAM by the sides, with the gold edge facing down towards the device.
    • Make sure your hands are clean and do not let your fingerprints get on the memory.
    • Line up the top corners of the new RAM with the top edges of the now empty panel.
    • Slide the RAM into the slot until it's firmly in place.
    • Once you hear the RAM stick click into place, you'll know you did it correctly.
    • Now just screw the panel door back on and you're finished!
Conclusão
Your new ASUS U30SD-XA1 RAM is ready to go. Now your device should run and work faster!
Julie M Paul
Membro desde: 07/17/15
164 Reputação
Autoria de 1 guia
Equipe
Texas Tech, Team 3-1, Rauch SU 2015 Membro de Texas Tech, Team 3-1, Rauch SU 2015
TTU-RAUCH-SU15S3G1
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 46
Duração total: 1,397
