Introdução
This circuit board is directly connected to the USB receivers and is responsible for reading information from USB drives as well as writing information on to USB drives. This board also contains the buttons for power and volume control.
O que você precisa
Remove the ten 10.7 mm screws using a Phillips #0 screwdriver from the back of the laptop.
Ferramenta utilizada nesse passo:Heavy-Duty Spudger$4.99
Using a heavy-duty spudger, pry the back cover up from the frame and completely remove.
Quase terminado!
Conclusão
