Ir para o conteúdo principal
ASUS Transformer Book Flip TP500LA RAM Replacement
O que você precisa
  1. ASUS Transformer Book Flip TP500LA RAM Replacement, RAM: passo 1, imagem 1 %32 ASUS Transformer Book Flip TP500LA RAM Replacement, RAM: passo 1, imagem 2 %32 ASUS Transformer Book Flip TP500LA RAM Replacement, RAM: passo 1, imagem 3 %32
    • Remove the ten 10 mm Phillips #0 screws found on the computer's back case.
  2. ASUS Transformer Book Flip TP500LA RAM Replacement: passo 2, imagem 1 %32 ASUS Transformer Book Flip TP500LA RAM Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Heavy-Duty Spudger
    Comprar
    • 'Slide a heavy-duty spudger in between the back case and the computer.
    • Slowly work around the edges to undo the clips to fully separate the back case from the computer.
    • Gently lift off the back case.
  3. ASUS Transformer Book Flip TP500LA RAM Replacement: passo 3, imagem 1 %32 ASUS Transformer Book Flip TP500LA RAM Replacement: passo 3, imagem 2 %32
    • Grasp the edges of the RAM case with your fingers.
    • Slowly lift the case upwards to remove the RAM case.
  4. ASUS Transformer Book Flip TP500LA RAM Replacement: passo 4, imagem 1 %32 ASUS Transformer Book Flip TP500LA RAM Replacement: passo 4, imagem 2 %32 ASUS Transformer Book Flip TP500LA RAM Replacement: passo 4, imagem 3 %32
    • Loosen the RAM's fastener clips by lifting one of the clips as you grasp the RAM card.
    • Carefully lift it away from the motherboard.
Conclusão
8 outras pessoas executaram este guia.
Solomon Dovinh
Membro desde: 04/10/17
403 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S13-G5, Forte Spring 2017 Membro de Cal Poly, Team S13-G5, Forte Spring 2017
CPSU-FORTE-S17S13G5
Membros da 4
Autoria de 6 guias
Um comentário
Thank you very much, easy to understand instruction. Where could I buy the parts like the RAM?
Marc LeBouthillier - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 22
Duração total: 2,647
