Introdução
Before proceeding with this guide, be sure you have all the required tools and the replacement hard drive.
O que você precisa
Remove the ten 10.7 mm Phillips #0 screws from the back cover of the Asus laptop.
Insert the heavy duty spudger between the back cover and the laptop frame. Pull the black pry tool along the edge of the laptop, unlatching the back cover from the frame.
5 outras pessoas executaram este guia.
