Ir para o conteúdo principal
ASUS TUF Gaming FX505DY RAM Replacement
O que você precisa
  1. ASUS TUF Gaming FX505DY RAM Replacement, Back Case: passo 1, imagem 1 %32
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. ASUS TUF Gaming FX505DY RAM Replacement: passo 2, imagem 1 %32 ASUS TUF Gaming FX505DY RAM Replacement: passo 2, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. ASUS TUF Gaming FX505DY RAM Replacement: passo 3, imagem 1 %32 ASUS TUF Gaming FX505DY RAM Replacement: passo 3, imagem 2 %32
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. ASUS TUF Gaming FX505DY RAM Replacement: passo 4, imagem 1 %32 ASUS TUF Gaming FX505DY RAM Replacement: passo 4, imagem 2 %32
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
  5. ASUS TUF Gaming FX505DY RAM Replacement, RAM: passo 5, imagem 1 %32 ASUS TUF Gaming FX505DY RAM Replacement, RAM: passo 5, imagem 2 %32
    • Pull the motherboard clips away from the sides of the RAM chip.
    • The RAM chip will pop up at an angle.
  6. ASUS TUF Gaming FX505DY RAM Replacement: passo 6, imagem 1 %32
    • At an angle, gently but firmly pull the RAM chip to remove it from the slot.
    • To install RAM, insert the RAM into the slot and press flat until the clips make an audible "click."
Conclusão
Carter Owen
Membro desde: 03/30/22
169 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 2-4, Mellen Spring 2022 Membro de UMass Dartmouth, Team 2-4, Mellen Spring 2022
UMASSD-MELLEN-S22S2G4
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 31
Duração total: 968
