Ir para o conteúdo principal
ASUS TUF Gaming FX505DY Battery Replacement
O que você precisa
  1. ASUS TUF Gaming FX505DY Battery Replacement, Back Case: passo 1, imagem 1 %32
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. ASUS TUF Gaming FX505DY Battery Replacement: passo 2, imagem 1 %32 ASUS TUF Gaming FX505DY Battery Replacement: passo 2, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. ASUS TUF Gaming FX505DY Battery Replacement: passo 3, imagem 1 %32 ASUS TUF Gaming FX505DY Battery Replacement: passo 3, imagem 2 %32
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. ASUS TUF Gaming FX505DY Battery Replacement: passo 4, imagem 1 %32 ASUS TUF Gaming FX505DY Battery Replacement: passo 4, imagem 2 %32
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
  5. ASUS TUF Gaming FX505DY Battery Replacement, Battery: passo 5, imagem 1 %32 ASUS TUF Gaming FX505DY Battery Replacement, Battery: passo 5, imagem 2 %32 ASUS TUF Gaming FX505DY Battery Replacement, Battery: passo 5, imagem 3 %32
    • Using an ESD-safe spudger, disconnect the battery connector by pulling the plug away from its port.
  6. ASUS TUF Gaming FX505DY Battery Replacement: passo 6, imagem 1 %32 ASUS TUF Gaming FX505DY Battery Replacement: passo 6, imagem 2 %32
    • Remove the 6 mm screw holding the battery in place using a Phillips #1 screwdriver.
    • Avoid cutting, puncturing, or otherwise damaging the battery. Li-ion batteries can combust or explode if damaged.
  7. ASUS TUF Gaming FX505DY Battery Replacement: passo 7, imagem 1 %32 ASUS TUF Gaming FX505DY Battery Replacement: passo 7, imagem 2 %32 ASUS TUF Gaming FX505DY Battery Replacement: passo 7, imagem 3 %32
    • Use a spudger to pry the retaining pin into the closed position to allow the battery frame to be removed.
  8. ASUS TUF Gaming FX505DY Battery Replacement: passo 8, imagem 1 %32
    • Lift the battery up out of the computer.
Conclusão
Uma outra pessoa concluiu este guia.
Ronald Brodeur
Membro desde: 03/30/22
109 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 2-4, Mellen Spring 2022 Membro de UMass Dartmouth, Team 2-4, Mellen Spring 2022
UMASSD-MELLEN-S22S2G4
Membros da 4
Autoria de 8 guias
Um comentário
What Is the serial number of the battery ?
Hector Garcia - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 26
Últimos 30 dias: 94
Duração total: 2,442
