Introdução
If your screen is glitching or the screen goes in and out, it might be a loose display connector. Use this guide if you need to check to see if your display connector is loose.
O que você precisa
Remove fifteen 10 mm screws from the bottom cover using a Phillips #0 screwdriver.
Once the back has been removed, locate this connection cable.
Check to see if the connector is in the pin slot; if not, locate the connector.
Quase terminado!
Conclusão
