Ir para o conteúdo principal
ASUS ROG Strix GL503VD-DB71 Fan Replacement
O que você precisa
  1. ASUS ROG Strix GL503VD-DB71 Fan Replacement, Fan: passo 1, imagem 1 %32 ASUS ROG Strix GL503VD-DB71 Fan Replacement, Fan: passo 1, imagem 2 %32 ASUS ROG Strix GL503VD-DB71 Fan Replacement, Fan: passo 1, imagem 3 %32
    • Flip the laptop over so that the bottom is facing up.
    • Remove the ten screws around the edges and in the center of the back case with a Phillips #1 screwdriver.
  2. ASUS ROG Strix GL503VD-DB71 Fan Replacement: passo 2, imagem 1 %32 ASUS ROG Strix GL503VD-DB71 Fan Replacement: passo 2, imagem 2 %32 ASUS ROG Strix GL503VD-DB71 Fan Replacement: passo 2, imagem 3 %32
    • Pry up the triangular service cover with a plastic opening tool.
    • Remove the single Phillips #1 screw beneath the cover.
    • Pry up the remainder of the back cover with a plastic opening tool and remove the back cover.
  3. ASUS ROG Strix GL503VD-DB71 Fan Replacement: passo 3, imagem 1 %32 ASUS ROG Strix GL503VD-DB71 Fan Replacement: passo 3, imagem 2 %32 ASUS ROG Strix GL503VD-DB71 Fan Replacement: passo 3, imagem 3 %32
    • Remove the four screws from the fans with a Phillips #1 screwdriver.
    • Unplug each of the fan connectors from the motherboard.
    • Remove each fan by lifting it from the case.
Conclusão
Uma outra pessoa concluiu este guia.
2 comentários
Hi! I have a GL503VD-EB72 and my fans look ever so slightly different. Trying to replace one right now but I’m seeing a lot of variety in what’s available on eBay and amazon…How can I tell if my fans are 5V or 12V?
Kirsten M - Responder
WTF i can find a 12 V for my GL503V
mrparisalexandre - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 31
Duração total: 4,648
