Ir para o conteúdo principal
ASUS ROG G750JW-RS72-CB RAM Replacement
O que você precisa
  1. ASUS ROG G750JW-RS72-CB RAM Replacement, Battery: passo 1, imagem 1 %32
    • Make sure you completely power down the computer before beginning this process.
    • With your finger, push this slide to the right. The battery should pop out of place.
  2. ASUS ROG G750JW-RS72-CB RAM Replacement: passo 2, imagem 1 %32
    • Pull the battery out of its place gently.
  3. ASUS ROG G750JW-RS72-CB RAM Replacement, RAM: passo 3, imagem 1 %32 ASUS ROG G750JW-RS72-CB RAM Replacement, RAM: passo 3, imagem 2 %32
    • Open flap in center and underneath you will find a screw, remove the 5.2mm screw with a Phillips #0 screwdriver.
  4. ASUS ROG G750JW-RS72-CB RAM Replacement: passo 4, imagem 1 %32 ASUS ROG G750JW-RS72-CB RAM Replacement: passo 4, imagem 2 %32
    • Once the screw is out, pull on the plastic tab to pull off the plastic cover.
  5. ASUS ROG G750JW-RS72-CB RAM Replacement: passo 5, imagem 1 %32
    • This exposes two hard drive caddies.
    • This also exposes two RAM slots.
  6. ASUS ROG G750JW-RS72-CB RAM Replacement: passo 6, imagem 1 %32
    • Push the metal tabs outward that are located on both sides of the top ram.
    • Remove the RAM from the slot.
    • Repeat with bottom RAM
  7. ASUS ROG G750JW-RS72-CB RAM Replacement: passo 7, imagem 1 %32 ASUS ROG G750JW-RS72-CB RAM Replacement: passo 7, imagem 2 %32
    • Align new RAM's key with the slot.
    • Place RAM in slot at a 45 degree angle downward, until the teeth are hidden inside of the socket itself.
    • Push down on RAM until a clicking sound is heard, meaning it is in place.
    • Repeat with top RAM
Conclusão
To reassemble your device, follow Steps 1-4 in reverse order.
Uma outra pessoa concluiu este guia.
Ellie Moran
Membro desde: 01/22/18
142 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S11-G5, Banghart Winter 2018 Membro de Cal Poly, Team S11-G5, Banghart Winter 2018
CPSU-BANGHART-W18S11G5
Membros da 4
Autoria de 5 guias
Um comentário
What about replacing the two internal RAM Modules?
Latiron London - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 22
Duração total: 1,184
