Introdução
In order to remove your hard drive for any reason, take the following steps to do so correctly.
Peças
Não são necessárias peças.
  1. Make sure you completely power down the computer before beginning this process.
    • Make sure you completely power down the computer before beginning this process.
    • With your finger, push this slide to the right. The battery should pop out of place.
  2. Pull the battery out of its place gently.
    • Pull the battery out of its place gently.
  3. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Lift up the flap using a plastic opening tool.
    • Lift up the flap using a plastic opening tool.
    • Hold the flap back with your finger.
  5. Unscrew the 5.2mm screw underneath the flap.
    • Unscrew the 5.2mm screw underneath the flap.
  6. Once the screw is out, pull on the plastic tab to pull off the plastic cover. Once the screw is out, pull on the plastic tab to pull off the plastic cover.
    • Once the screw is out, pull on the plastic tab to pull off the plastic cover.
  7. Unscrew the 5.2mm screws holding the hard drive in place. Gently pull the rubber hard drive mount to the side. Pull the drive out.
    • Unscrew the 5.2mm screws holding the hard drive in place.
    • Gently pull the rubber hard drive mount to the side.
    • Pull the drive out.
Conclusão
Joseph Rockwell
243 reputação
2 Guides authored
Equipe
Cal Poly, Team S11-G5, Banghart Winter 2018 Membro de Cal Poly, Team S11-G5, Banghart Winter 2018
CPSU-BANGHART-W18S11G5
4 Membros
5 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Todo: 120
