Introdução
In this guide, we will replace the screen of the Asus ROG G750JW-RS72-CB.
O que você precisa
With your finger, push this slide to the right. The battery should pop out of place.
Lift up the flap using a plastic opening tool.
Hold the flap back with your finger.
Remove the 8.5mm screws holding the bottom half of the laptop together.
4 outras pessoas executaram este guia.
Um comentário
Super helpful.
Upon re-pasting GPU I noticed that not only GPU chip was covered in thermal paste surrounding chips were literately covered with thermal paste to is that normal?
