Ir para o conteúdo principal
ASUS ROG G750JW-RS72-CB Display Assembly Replacement
O que você precisa
  1. ASUS ROG G750JW-RS72-CB Display Assembly Replacement, Battery: passo 1, imagem 1 %32
    • Make sure you completely power down the computer before beginning this process.
    • With your finger, push this slide to the right. The battery should pop out of place.
  2. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: passo 2, imagem 1 %32
    • Pull the battery out of its place gently.
  3. ASUS ROG G750JW-RS72-CB Display Assembly Replacement, Hard Drive: passo 3, imagem 1 %32
    • Lift up the flap using a plastic opening tool.
    • Hold the flap back with your finger.
  4. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: passo 4, imagem 1 %32
    • Unscrew the 5.2mm screw underneath the flap.
  5. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: passo 5, imagem 1 %32 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: passo 5, imagem 2 %32
    • Once the screw is out, pull on the plastic tab to pull off the plastic cover.
  6. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: passo 6, imagem 1 %32 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: passo 6, imagem 2 %32 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: passo 6, imagem 3 %32
    • Unscrew the 5.2mm screws holding the hard drive in place.
    • Gently pull the rubber hard drive mount to the side.
    • Pull the drive out.
  7. ASUS ROG G750JW-RS72-CB Display Assembly Replacement, Display Assembly: passo 7, imagem 1 %32
    • Remove the 8.5mm screws holding the bottom half of the laptop together.
  8. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: passo 8, imagem 1 %32 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: passo 8, imagem 2 %32
    • Take a metal separater and gently pry open the back end of the laptop halves.
  9. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: passo 9, imagem 1 %32 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: passo 9, imagem 2 %32
    • Remove the connector connecting the screen and the motherboard
  10. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: passo 10, imagem 1 %32 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: passo 10, imagem 2 %32
    • Unscrew the 6.8mm screws holding the hinges of the screen to the bottom half of the computer.
    • Detach the screen from the hinges of the laptop.
    • Be careful not to damage the connecting wires when detaching the screen.
  11. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: passo 11, imagem 1 %32 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: passo 11, imagem 2 %32
    • Use a metal separator to carefully separate the bottom half of the laptop.
  12. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: passo 12, imagem 1 %32
    • Gently unplug the cables connecting the screen to the motherboard.
    • The display assembly can now be freely separated.
Conclusão
4 outras pessoas executaram este guia.
Sully Chen
Membro desde: 01/22/18
435 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S11-G5, Banghart Winter 2018 Membro de Cal Poly, Team S11-G5, Banghart Winter 2018
CPSU-BANGHART-W18S11G5
Membros da 4
Autoria de 5 guias
Um comentário
Super helpful.
Upon re-pasting GPU I noticed that not only GPU chip was covered in thermal paste surrounding chips were literately covered with thermal paste to is that normal?
Timepusher - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 16
Duração total: 1,842
