Ir para o conteúdo principal
ASUS ROG G46VW Indicator Lights Replacement
O que você precisa
  1. ASUS ROG G46VW Indicator Lights Replacement, RAM: passo 1, imagem 1 %32 ASUS ROG G46VW Indicator Lights Replacement, RAM: passo 1, imagem 2 %32
    • Lift the screw cover and remove the screw using a Phillips #0 screwdriver.
  2. ASUS ROG G46VW Indicator Lights Replacement: passo 2, imagem 1 %32
    • Remove the RAM cover by lifting the screw cover and pulling away firmly.
  3. ASUS ROG G46VW Indicator Lights Replacement: passo 3, imagem 1 %32 ASUS ROG G46VW Indicator Lights Replacement: passo 3, imagem 2 %32
    • Push outwards on the clips to release the RAM stick. The stick should pop up at an angle.
  4. ASUS ROG G46VW Indicator Lights Replacement: passo 4, imagem 1 %32
    • Pull out the RAM stick carefully.
    • Do not use a prying motion as this will damage the hardware. Be careful not to damage the gold section of the RAM stick.
  5. ASUS ROG G46VW Indicator Lights Replacement: passo 5, imagem 1 %32
    • Repeat steps 3-4 to remove the second RAM stick.
  6. ASUS ROG G46VW Indicator Lights Replacement, Speaker Cover: passo 6, imagem 1 %32
    • Gently pry the back hinge cover piece away from the device.
  7. ASUS ROG G46VW Indicator Lights Replacement: passo 7, imagem 1 %32
    • Disconnect the speaker cable from the motherboard.
  8. ASUS ROG G46VW Indicator Lights Replacement, Keyboard: passo 8, imagem 1 %32
    • Remove the two screws from underneath the RAM cover.
  9. ASUS ROG G46VW Indicator Lights Replacement: passo 9, imagem 1 %32
    • Remove all of the screws from the bottom of the case.
    • If replacing the screen, remove the rubber feet to reveal two more screws.
  10. ASUS ROG G46VW Indicator Lights Replacement: passo 10, imagem 1 %32
    • Turn the laptop over and remove the screws as shown
  11. ASUS ROG G46VW Indicator Lights Replacement: passo 11, imagem 1 %32
    • Carefully pry the keyboard away using your spudger and the opening tools.
    • Be sure not to damage the clips holding the keyboard to the bottom case.
  12. ASUS ROG G46VW Indicator Lights Replacement: passo 12, imagem 1 %32 ASUS ROG G46VW Indicator Lights Replacement: passo 12, imagem 2 %32
    • Detach the ribbon cable by releasing the clip
  13. ASUS ROG G46VW Indicator Lights Replacement, Indicator Lights: passo 13, imagem 1 %32
    • With the motherboard exposed, locate the Indicator Lights and their white plastic housing piece.
  14. ASUS ROG G46VW Indicator Lights Replacement: passo 14, imagem 1 %32
    • Remove all 3 screws from the motherboard connection using the Phillips #0 screwdriver.
    • Pull the plastic white housing piece away from the case.
  15. ASUS ROG G46VW Indicator Lights Replacement: passo 15, imagem 1 %32
    • Locate the flat LED cable that connects the lights to the motherboard.
    • Flip the black cover upwards before pulling on the cable.
    • Repeat for the other connector piece.
Conclusão
Nicolas Catano
Membro desde: 09/24/18
104 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 392
