Ir para o conteúdo principal
ASUS R554L Battery Replacement
O que você precisa
  1. ASUS R554L Battery Replacement, Battery: passo 1, imagem 1 %32
    • Flip the laptop so the bottom is facing upward.
    • Remove ten screws using a Phillips #0 screwdriver.
  2. ASUS R554L Battery Replacement: passo 2, imagem 1 %32 ASUS R554L Battery Replacement: passo 2, imagem 2 %32 ASUS R554L Battery Replacement: passo 2, imagem 3 %32
    • Using your fingertips, carefully pull the backplate in an upright direction.
    • Continue along the edges until the backplate is fully removed.
    • It's normal to hear cracking while pulling up on the plate.
  3. ASUS R554L Battery Replacement: passo 3, imagem 1 %32 ASUS R554L Battery Replacement: passo 3, imagem 2 %32 ASUS R554L Battery Replacement: passo 3, imagem 3 %32
    • Remove the four screws from the battery using a Phillips #0 screwdriver.
    • Pull up on the cable connected to the motherboard to remove.
    • Remove the battery from the bay.
  4. ASUS R554L Battery Replacement: passo 4, imagem 1 %32 ASUS R554L Battery Replacement: passo 4, imagem 2 %32 ASUS R554L Battery Replacement: passo 4, imagem 3 %32
    • Place the new battery in the bay.
    • Install the battery cable to the motherboard, applying pressure in a downward direction.
    • Screws the screws back in using a Phillips #0 screwdriver.
  5. ASUS R554L Battery Replacement: passo 5, imagem 1 %32 ASUS R554L Battery Replacement: passo 5, imagem 2 %32 ASUS R554L Battery Replacement: passo 5, imagem 3 %32
    • Align the backplate.
    • Starting with the upper right corner, apply pressure in a downward angle.
    • Repeat the process around the backplate until it's fully secure.
  6. ASUS R554L Battery Replacement: passo 6, imagem 1 %32 ASUS R554L Battery Replacement: passo 6, imagem 2 %32
    • Screw the backplate screws back in using a Phillips #0 screwdriver.
Conclusão
Once the new battery is installed, leave the charger connected to the laptop over night to ensure the battery is holding a charge
Uma outra pessoa concluiu este guia.
Joshua Chavez
Membro desde: 01/31/22
160 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 23
Últimos 30 dias: 148
Duração total: 4,935
