Ir para o conteúdo principal
ASUS Q524U Hard Drive Replacement
O que você precisa
  1. ASUS Q524U Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32
    • Turn the laptop on its back, and place it on a flat and smooth surface. Identify the location of the back panels screws.
  2. ASUS Q524U Hard Drive Replacement: passo 2, imagem 1 %32 ASUS Q524U Hard Drive Replacement: passo 2, imagem 2 %32 ASUS Q524U Hard Drive Replacement: passo 2, imagem 3 %32
    • Remove all ten 1.3mm screws on the outer edge of the back panel using the T4 screwdriver.
  3. ASUS Q524U Hard Drive Replacement: passo 3, imagem 1 %32
    • Using the opening tool or spudger, remove the back panel by working your way around the perimeter and pry it open gently.
  4. ASUS Q524U Hard Drive Replacement: passo 4, imagem 1 %32
    • Remove the back panel, exposing the motherboard.
    • Set the panel aside, skin up to avoid scratches.
  5. ASUS Q524U Hard Drive Replacement: passo 5, imagem 1 %32
    • Using the T4 screwdriver, remove the four 1.3 mm screws connecting the hard drive to the motherboard.
    • The hard-drive is located in the bottom left corner of the motherboard.
  6. ASUS Q524U Hard Drive Replacement: passo 6, imagem 1 %32 ASUS Q524U Hard Drive Replacement: passo 6, imagem 2 %32
    • Once all the screws are removed from the port, lift the hard drive out of its casing. After, disconnect the hard drive from the motherboard.
Linha de Chegada
3 outras pessoas executaram este guia.
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 67
Ao todo: 3,636
