Introdução
If the screen is damaged, or has an incorrect display, it should replaced. The following is a comprehensive guide for replacing the screen.
O que você precisa
Flip the laptop on its back side with the battery facing toward you.
Slide the tabs with lock/unlock symbol, to the unlock position.
Grabbing the top edge of the battery, lift upward to relieve the battery from its slot.
3 outras pessoas executaram este guia.
Um comentário
Can you tell me what is the part number and description for the display, I need to order one to replace mi ASUS broken screen. Thanks in advance...!!!
