Ir para o conteúdo principal
ASUS Q400A-BHI7N03 Battery Replacement
  1. ASUS Q400A-BHI7N03 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the laptop.
    • Disconnect the charging cable from the laptop.
    • Failure to unplug the cable could result in electric shock.
    • Flip the laptop over so that it is upside down.
    • The slightly raised area is the battery.
    • Orient the laptop so that the battery is away from you.
  2. ASUS Q400A-BHI7N03 Battery Replacement: passo 2, imagem 1 %32
    • In the top right corner, push the tab to the right to the unlocked position.
  3. ASUS Q400A-BHI7N03 Battery Replacement: passo 3, imagem 1 %32 ASUS Q400A-BHI7N03 Battery Replacement: passo 3, imagem 2 %32
    • Find the tab in the top left corner. With one finger, pull the tab to the left to the unlocked position.
    • While holding this tab in the unlocked position, gently pull the battery away from you.
Conclusão
To reinsert your battery, follow these instructions in reverse order. Remember to re-lock the tab in step 2.
Matthew Gold
Membro desde: 01/19/17
401 Reputação
Autoria de 4 guias
Equipe
UC Davis, Team 1-4, Rodger Winter 2017 Membro de UC Davis, Team 1-4, Rodger Winter 2017
UCD-RODGER-W17S1G4
Membros da 5
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 16
Duração total: 694
