Ir para o conteúdo principal
ASUS Q324UA-BHI7T17 Track Pad Replacement
O que você precisa
  1. ASUS Q324UA-BHI7T17 Track Pad Replacement, Track Pad: passo 1, imagem 1 %32 ASUS Q324UA-BHI7T17 Track Pad Replacement, Track Pad: passo 1, imagem 2 %32
    • Remove all ten 5mm screws from the backplate using a Phillips #0 Screwdriver.
  2. ASUS Q324UA-BHI7T17 Track Pad Replacement: passo 2, imagem 1 %32
    • Carefully remove the backplate using the plastic opening tool.
  3. ASUS Q324UA-BHI7T17 Track Pad Replacement: passo 3, imagem 1 %32
    • Lift up the back plate and slide it to the back of the computer to remove.
  4. ASUS Q324UA-BHI7T17 Track Pad Replacement: passo 4, imagem 1 %32 ASUS Q324UA-BHI7T17 Track Pad Replacement: passo 4, imagem 2 %32 ASUS Q324UA-BHI7T17 Track Pad Replacement: passo 4, imagem 3 %32
    • Disconnect the battery from the laptop in the upper left side of the battery, using tweezers.
  5. ASUS Q324UA-BHI7T17 Track Pad Replacement: passo 5, imagem 1 %32
    • Remove the six 5 mm screws holding the battery using a Phillips #0 screwdriver.
  6. ASUS Q324UA-BHI7T17 Track Pad Replacement: passo 6, imagem 1 %32
    • Carefully remove the battery using the plastic opening tool.
  7. ASUS Q324UA-BHI7T17 Track Pad Replacement: passo 7, imagem 1 %32 ASUS Q324UA-BHI7T17 Track Pad Replacement: passo 7, imagem 2 %32 ASUS Q324UA-BHI7T17 Track Pad Replacement: passo 7, imagem 3 %32
    • Disconnect the trackpad from the motherboard using tweezers.
    • The white tab flips up.
  8. ASUS Q324UA-BHI7T17 Track Pad Replacement: passo 8, imagem 1 %32 ASUS Q324UA-BHI7T17 Track Pad Replacement: passo 8, imagem 2 %32
    • Remove the two 5mm screws holding in the trackpad using a Phillips #0 screwdriver.
  9. ASUS Q324UA-BHI7T17 Track Pad Replacement: passo 9, imagem 1 %32 ASUS Q324UA-BHI7T17 Track Pad Replacement: passo 9, imagem 2 %32
    • Remove adhesive tape tethering the trackpad to the motherboard with tweezers.
  10. ASUS Q324UA-BHI7T17 Track Pad Replacement: passo 10, imagem 1 %32 ASUS Q324UA-BHI7T17 Track Pad Replacement: passo 10, imagem 2 %32 ASUS Q324UA-BHI7T17 Track Pad Replacement: passo 10, imagem 3 %32
    • Carefully remove the trackpad using the plastic opening tool.
    • Lift up and side track toward the back of the computer to remove.
Conclusão
Gabriel survance
Membro desde: 04/01/19
343 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S2-G2, Harley Spring 2019 Membro de IUPUI, Team S2-G2, Harley Spring 2019
IUPUI-HARLEY-S19S2G2
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 177
