Ir para o conteúdo principal
ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement
O que você precisa
  1. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement, Battery: passo 1, imagem 1 %32
    • Remove all 10 Phillips screws on the backplate.
    • All 10 screws are 0.55 inches and 20 mm in diameter.
  2. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: passo 2, imagem 1 %32 ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: passo 2, imagem 2 %32
    • Carefully remove the backplate using the plastic opening tool.
  3. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: passo 3, imagem 1 %32
    • Locate the battery near the bottom.
  4. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Next, lift up the battery connector from the laptop in the upper left side of the battery, using tweezers or spudger.
    • Make sure to complete this step with caution, because if the battery is not unplugged, the motherboard may shock you.
  5. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: passo 5, imagem 1 %32 ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: passo 5, imagem 2 %32
    • Remove the six screws holding in the battery with a Phillips #0 screwdriver.
    • Once battery is lifted out and removed, proper dispose of the old battery.
    • Each screw is 0.5 cm in length and 0.5 cm in diameter.
  6. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement, Power & Volume Button PCB Board: passo 6, imagem 1 %32
    • Remove the screw holding the Power chip in place and remove it using a Phillips head #0 screw driver.
    • Screw length is 0.5 cm in length and 0.5 cm in diameter
  7. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: passo 7, imagem 1 %32 ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: passo 7, imagem 2 %32 ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: passo 7, imagem 3 %32
    • Locate the ribbon connector connecting the power chip to the mother board.
    • Simply lift up the black component and the ribbon connector should be released, then the power chip should pop out easily.
    • Discard of the old power chip properly.
Conclusão
Scott Santiago
Membro desde: 10/17/17
534 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team S1-G1, Simcock Fall 2017 Membro de UMass Dartmouth, Team S1-G1, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G1
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 666
