Introdução
This guide will take you through the steps of replacing a cooling fan that is no longer working.
O que você precisa
Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
Use a Phillips #00 screwdriver to remove all three 4mm screws around the fan.
Using the same screw driver, remove the four 4mm screws from the part of the fan that is above the processor.
Conclusão
