Ir para o conteúdo principal
ASUS Q302L Display Replacement
O que você precisa
  1. ASUS Q302L Display Replacement, Back Case: passo 1, imagem 1 %32
    • Make sure the laptop is disconnected from a power supply and is TURNED OFF.
    • Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
  2. ASUS Q302L Display Replacement: passo 2, imagem 1 %32 ASUS Q302L Display Replacement: passo 2, imagem 2 %32 ASUS Q302L Display Replacement: passo 2, imagem 3 %32
    • Wedge a plastic opening tool under the rear case near the hinge.
    • Pry around the outer edge to release the plastic clips holding the rear case to the laptop.
  3. ASUS Q302L Display Replacement: passo 3, imagem 1 %32
    • Once the cover is free from all the clips, remove the cover from the laptop.
  4. ASUS Q302L Display Replacement, Battery: passo 4, imagem 1 %32
    • Use a Phillips #0 screwdriver and remove all five 5 mm screws securing the battery.
  5. ASUS Q302L Display Replacement: passo 5, imagem 1 %32 ASUS Q302L Display Replacement: passo 5, imagem 2 %32 ASUS Q302L Display Replacement: passo 5, imagem 3 %32
    • Gently wedge a plastic opening tool under the connector.
    • Pry only on the connector not the socket itself or you risk damage to the motherboard.
    • Carefully lift the connector up away from the socket to disconnect it.
  6. ASUS Q302L Display Replacement: passo 6, imagem 1 %32 ASUS Q302L Display Replacement: passo 6, imagem 2 %32
    • Once the screws and connector are removed, simply pull out the battery from its place.
  7. ASUS Q302L Display Replacement, Display: passo 7, imagem 1 %32 ASUS Q302L Display Replacement, Display: passo 7, imagem 2 %32
    • Use a Phillips #00 screw driver to remove the five 10mm screws at the hinges.
  8. ASUS Q302L Display Replacement: passo 8, imagem 1 %32 ASUS Q302L Display Replacement: passo 8, imagem 2 %32 ASUS Q302L Display Replacement: passo 8, imagem 3 %32
    • Peel back the tape and remove the two connectors.
  9. ASUS Q302L Display Replacement: passo 9, imagem 1 %32 ASUS Q302L Display Replacement: passo 9, imagem 2 %32
    • Pull up on the black tab to remove the connector that connects to the motherboard.
    • Unplug the hard drive cable from the hard drive.
    • Carefully remove the cables from the track that they run through.
  10. ASUS Q302L Display Replacement: passo 10, imagem 1 %32 ASUS Q302L Display Replacement: passo 10, imagem 2 %32
    • Carefully remove the display from the rest of the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Nicholas Lozier
Membro desde: 04/01/19
290 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S2-G4, Harley Spring 2019 Membro de IUPUI, Team S2-G4, Harley Spring 2019
IUPUI-HARLEY-S19S2G4
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 1,107
