Ir para o conteúdo principal
ASUS Q302L Battery Replacement
O que você precisa
  1. ASUS Q302L Battery Replacement, Back Case: passo 1, imagem 1 %32
    • Make sure the laptop is disconnected from a power supply and is TURNED OFF.
    • Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
  2. ASUS Q302L Battery Replacement: passo 2, imagem 1 %32 ASUS Q302L Battery Replacement: passo 2, imagem 2 %32 ASUS Q302L Battery Replacement: passo 2, imagem 3 %32
    • Wedge a plastic opening tool under the rear case near the hinge.
    • Pry around the outer edge to release the plastic clips holding the rear case to the laptop.
  3. ASUS Q302L Battery Replacement: passo 3, imagem 1 %32
    • Once the cover is free from all the clips, remove the cover from the laptop.
  4. ASUS Q302L Battery Replacement, Battery: passo 4, imagem 1 %32
    • Use a Phillips #0 screwdriver and remove all five 5 mm screws securing the battery.
  5. ASUS Q302L Battery Replacement: passo 5, imagem 1 %32 ASUS Q302L Battery Replacement: passo 5, imagem 2 %32 ASUS Q302L Battery Replacement: passo 5, imagem 3 %32
    • Gently wedge a plastic opening tool under the connector.
    • Pry only on the connector not the socket itself or you risk damage to the motherboard.
    • Carefully lift the connector up away from the socket to disconnect it.
  6. ASUS Q302L Battery Replacement: passo 6, imagem 1 %32 ASUS Q302L Battery Replacement: passo 6, imagem 2 %32
    • Once the screws and connector are removed, simply pull out the battery from its place.
Conclusão
khalifa
Membro desde: 03/02/17
107 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S13-G4, Cagle Spring 2017 Membro de USF Tampa, Team S13-G4, Cagle Spring 2017
USFT-CAGLE-S17S13G4
Membros da 3
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 23
Duração total: 5,967
