Ir para o conteúdo principal
ASUS Padfone X mini Station Battery Replacement
O que você precisa
  1. ASUS Padfone X mini Station Battery Replacement, Battery: passo 1, imagem 1 %32
    • Insert the plastic opening tool between the edge of the screen and the back cover.
    • Gently pry them apart. Use hands to pull them apart if necessary.
  2. ASUS Padfone X mini Station Battery Replacement: passo 2, imagem 1 %32 ASUS Padfone X mini Station Battery Replacement: passo 2, imagem 2 %32
    • Remove the three pieces of tape that secure the battery and its wires. Peel gently so you don’t damage any wires.
  3. ASUS Padfone X mini Station Battery Replacement: passo 3, imagem 1 %32 ASUS Padfone X mini Station Battery Replacement: passo 3, imagem 2 %32 ASUS Padfone X mini Station Battery Replacement: passo 3, imagem 3 %32
    • Disconnect the ribbon from the motherboard by gently pulling with your fingers.
    • Using the opening tools, pry the battery off of the adhesive.
    • Be careful not to pull the battery out right away. The ribbon cable is tucked beneath another wire.
Conclusão
Alexzander Pastore
Membro desde: 10/26/18
389 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team S2-G7, Peak Fall 2018 Membro de UMass Dartmouth, Team S2-G7, Peak Fall 2018
UMASSD-PEAK-F18S2G7
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 492
