Ir para o conteúdo principal
ASUS PadFone X Rear Facing Camera Replacement
O que você precisa
  1. ASUS PadFone X Rear Facing Camera Replacement, Remove the back panel: passo 1, imagem 1 %32 ASUS PadFone X Rear Facing Camera Replacement, Remove the back panel: passo 1, imagem 2 %32
    • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upward.
    • Work your way around the phone until the entire back cover is loose.
  2. ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: passo 2, imagem 1 %32 ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: passo 2, imagem 2 %32 ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: passo 2, imagem 3 %32
    • Remove the thirteen 3.6 mm screws using the torx T5 bit in the screwdriver.
  3. ASUS PadFone X Rear Facing Camera Replacement, Remove the Mid-Frame.: passo 3, imagem 1 %32 ASUS PadFone X Rear Facing Camera Replacement, Remove the Mid-Frame.: passo 3, imagem 2 %32
    • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
  4. ASUS PadFone X Rear Facing Camera Replacement, Remove the camera connector.: passo 4, imagem 1 %32
    • Use the blue plastic opening tool to gently pry the camera connector up from its socket on the motherboard.
    • Applying too much force may damage the connector.
  5. ASUS PadFone X Rear Facing Camera Replacement, Remove the camera.: passo 5, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using the tweezers, remove the rear camera from the Padfone X.
    • The camera is lightly glued to the motherboard. You may need to use a plastic opening tool to loosen the adhesive under the camera.
  6. ASUS PadFone X Rear Facing Camera Replacement, Replacing the camera.: passo 6, imagem 1 %32
    • Once the camera has been pulled out, replace the old camera with a new camera.
Conclusão
nestor
Membro desde: 10/07/14
101 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 8-4, Leahy Fall 2014 Membro de USF Tampa, Team 8-4, Leahy Fall 2014
USFT-LEAHY-F14S8G4
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 529
